Run ETL from command line
2448
10-31-2012 10:47 AM
JackGeren
Is it possible to run an ETL tool model from the Windows command line ">"?
BruceHarold
Esri Frequent Contributor
Hello J
Yes, if you write a standalone Python script that imports arcpy and the Data Interoperability extension and imports/adds your toolbox, you can execute the tool from a command shell.  This is the same workflow as any other geoprocessing functionality called from a command line.
Regards
