Original User: offwhite
I am a green newby working my way through generating contours from LiDAR images to export contour lines into my architectural software, [ArchiCAD], in DWG format to generate better site plans for my design work. I am all of the way there with a single glitch........
When the DWG is placed/imported into my program what should, [as in I want to be], be continious polylines some up as a bi-gillion single little lines, creating arcs andcurves by splitting them into thousands of little elements.
I presume this is pilot error and with some guidance, [thank you in advance!], on how to adjust my settings this can be overcome. Any help will be greatly appreciated!
