Replication between datasets at the same geodatabase
409
11-07-2013 03:12 AM
NathalieMello
We need to know if its possible to replicate featureclasses from a dataset to a different dataset of the same same arcsde geodatabase.
Nathalie - CGI
AsrujitSengupta
Regular Contributor III
Nathalie,
As mentioned in the links:
Geodatabase replication allows you to create copies of data across two or more geodatabases such that changes to the data may be synchronized.
Replicas and geodatabases:
http://resources.arcgis.com/en/help/main/10.1/index.html#//003n000000vp000000
We need atleast two geodatabases for this functionality.
Regards,
NathalieMello
Hello asrujit,
Thank you for your response.
Regards,
Nathalie
Nathalie,
Regards,
