Relationship Classes appear across all schemas
785
11-13-2013 01:36 PM
ChadMarch1
New Contributor III
I've got some relationship classes I created in one schema, but they appear across all schemas even though my schemas don't have general viewer access to the whole database. Anybody know why and what I can do to make sure they appear only in their schema or general viewer accounts?
ArcGIS 10.1 sp2, SQL Server 2012, Windows Server 2012
AsrujitSengupta
Regular Contributor III
Chad,
The behavior you are observing is by design.
The below article mentions Feature Datasets, but that seems to be true for Relationship classes as well:
http://support.esri.com/es/knowledgebase/techarticles/detail/22721
You can have a look at the below scripts though:
�?� http://arcscripts.esri.com/details.asp?dbid=13428
�?� http://arcscripts.esri.com/details.asp?dbid=13886
Regards,
MarcoBoeringa
MVP Regular Contributor
It is doubtful if these tools will work in 10.x, since they were designed for 9.x, and the geodatabase system tables underwent major changes from 9.x to 10.x (conversion to XML based), most likely rendering the suggested solutions useless.
AsrujitSengupta
Marco,
I didn't give those links as solution/workaround for the behavior...those are just for reference..
Regards,
