I have a shapfile with simplified chinese characters. I added a *.cpg (cp936) and the data displayed correctly in ArcMap 10.2.2
However, when I copied the shapfile with *.cpg to another computer, which was ArcMap 10.1, the data was not showing properly.
Is it possible to use the codepage file in ArcMap 10.1?
Best Regards,
Amy
according to the 10.1 help files, yes, but did you give the *.cpg file the same name as the shapefile? ie test.shp and test.cpg ArcGIS Help 10.1
There is at least one article on codepages in the knowledge base, perhaps there were some version changes, but you should have a look at this, sounds like it needs a conversion
http://support.esri.com/en/bugs/nimbus/role/beta10_1/TklNMTAyMjU5
21106 - Read and write shapefile and dBASE files encoded in various code pages
Thanks for the info.
I have my user's locale set to Simplified Chinese, and it finally worked in ArcMap 10.1
