Environment: Arc SDE 10.1 , Oracle 11g r2, Arcgis Server 10.1
I have table with linestring clob column, the linestring are larger than 4000 bytes.
When I try to do a select using sde.st_linefromtext on the clob column, i get:
System.Data.OracleClient.OracleException: ORA-20004: Error generating shape from text: Invalid text used to construct geometry (-1).
ORA-06512: at "SDE.ST_GEOMETRY_SHAPELIB_PKG", line 12
ORA-06512: at "SDE.ST_LINEFROMTEXT", line 58
But it works fine when I run the same select on the same column in different environment: Arc SDE 10 , Oracle 10, Arcgis Server 10
Does Arcgis 10.1 has size limitation?
Ido
