Problem using SSURGO Data
1128
06-27-2012 09:27 AM
JosiahNewman
I am having an issue in trying to add tables of information downloaded through the Web Soil Survey (SSURGO Data) to ArcMap 9.3.1.  The data contains many tables that are downloaded as .txt files.  I am having trouble putting this data in a usable format so that I can link it to the soil polygons present in the main polygon data set.  Any help or advice would be much appreciated, I have tried everything that I can think of at this point!
JoeFlannery
Occasional Contributor III
Go to this site (http://soildatamart.nrcs.usda.gov/Templates.aspx) and download the MS-Access database template "soildb_US_2002".  This template has a nifty macro that imports the pipe-delimited txt files and then you can tap the Access database tables from ArcMap.
JohnSobetzer
You might look at the Soil Data Viewer.
JoeFlannery
JosiahNewman
Thank you so much!  I have been beating my head off the wall for the bulk of the month, if I ever meet you, I will buy you a beer.
RichNauman
New Contributor III
Depending on what SSURGO fields you need you may be able to use the soil layers available through the Landscape Layers group in ArcGIS.com.
