We are building a Web application in Javascript that lets a user digitize a polygon that we use to clip data. The application uses WGS_1984_Web_Mercator_Auxiliary_Sphere. Using Python I take the Fetaure Set passed by the application and turn it into a permanent feature class and assign the projection to WGS_1984_Web_Mercator_Auxiliary_Sphere. When I try to look at the feature class I get the following error message:
Error
The selected object failed to draw:
GeoScratch.DBO.PHSClipArea_WMA: The coordinate system description is invalid
I'm able to reproject the feature class which works without any problems.
Any ideas?
