Problem comparing ESRI census tract centroid to SQL Server point centroid
197
07-27-2017 12:36 PM
How would I make a valid comparison using ARCGIS census tract population centroids within a one mile radius of an address to the results using a SQL Server geography spatial index of latitude and longitude points of centers of population within a one mile radius around the same address?  When counting the census tracts with population weighted centroids from ESRI ARCGIS that are within a one mile radius around an address in San Francisco, California as compared to the US Census Bureau center of population census tract points within a one mile radius of the same address as indicated by latitude and longitude using a SQL Server geography spatial index of the points, I am computing significantly different results.
Reply
MVP Regular Contributor
What are you trying to compare?  Number of results yielded by each process?  Difference of address values between the two?
Reply
The number of tracts returned within a one mile radius.
Reply
You can use the Select By Location tool and specify a search radius within that.  Also, you can select a feature within ArcMap and use only that selected feature (center point) as the search input.
Reply
