Polyline Shapefile with single feature to multi feature
592
01-14-2014 03:22 AM
PieterSnyders1
I have a shapefile of contour lines, the problem is it is a single feature. I need to break the line into multiple lines and give it an elevation value. What would be the best tool to use?
ScottMoyer
Pieter,
The 'Explode' tool on the Advanced Editing toolbar will create many lines from one, as long as they are separate (multipart).
Scott
MarkBoucher
I was thinking one could use the mulitpart to single part tool.
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//00170000003r000000
It looks like it does the same thing per this page.
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//001t0000007p000000.htm
PieterSnyders1
Thank you for the prompt responses, I will try these tools and let you know if it works!
PieterSnyders1
Hey Guys,
Thank you very much for the help. The Explode tool works perfectly. As simple as select feature and press the Explode Tool on advanced editing tool bar!
Have a good day!
