offsetting points from a point with known coordinate
390
04-09-2018 11:10 AM
LucianaOmar
I have a serie of points with known coordinates and another series of points in the same alignments with different offsets from the known points that don`t have coordinates. I want to know how can I calculate the coordinates of these offset points.
Thank you
RobertBorchert
Frequent Contributor III
use calculate geometry or use the Add XY Coordinates Tool.
LucianaOmar
Hi Robert,
I would do it if I had the coordinates of the points which I don’t. For example a have the coordinate of point A and Point B, but I want the coordinate of a point 100 metres from A. I was thinking to use linear referencing system, but it is not working. Do you have an idea what should I do?
Thank you,
Luciana
