mxdperfstat for SQL Server with the default instance name
977
02-12-2014 02:18 AM
HenWagner
Hi
First time I'm trying to use the mxdperfstat on a non-named instance.
Normally I would specify ..... -host <myhost> -instance <myinstance> .... and it works perfectly.
However, specifying only the host ..... -host <myhost> ...... (without the instance name) wouldn't work.
According to this :https://stackoverflow.com/questions/3449397/connection-string-for-default-instance-like-for-named-in...
Specifying MSSQLSERVER as the instance name wouldn't work, and in fact it doesn't.
Has anybody used mxdperfstat with a default instance name?
MarcoBoeringa
MVP Regular Contributor
I don't know if it is a good replacement, but this ESRI tool:
Calibrating ArcGIS Performance with PerfQAnalyzer: New Build Available for Download
seems more recently maintained (recent update this month), and may do what you want.
CalinArens
I had the same problem. To fix, use: -host <myhost> -instance " "
