Minimum Bounding Geometry Output Group Field has No Data
1456
12-29-2016 08:24 AM
GregWhite2
New Contributor III
In Model Builder, using minimum bounding geometry tool, whenever my output is our enterprise geodatabase the group field has no values BUT the grouping is done correctly. Writing to "In_Memory" OR another output type results in a populated group field. WHY???????
JoshuaBixby
MVP Esteemed Contributor
With issues like this, or even just in general, it helps to provide some basic platform and version information.  What version of ArcMap or ArcGIS Pro are you using?  What version is your enterprise geodatabase?  What DBMS is your enterprise geodatabase stored in?
GregWhite2
New Contributor III
I guess I a more voicing my frustration with time lost than looking for an answer ha ha ha. But it is SQL Server and ArcMap 10.4.1. Not sure the version of the enterprise geodatabse.  It might be a bug cause if I output to "in_memory" and then write to the same geodatabase the field is populated.
