You can use Python script.FeatureClassToShapefile example (Python window):import arcpy
from arcpy import env
env.workspace = "C:/data/airport.gdb"
arcpy.FeatureClassToShapefile_conversion(["county", "parcels", "schools"],
"C:/output")
FeatureClassToShapefile example 2 (stand-alone script):# Name: FeatureClassToShapefile_Example2.py
# Description: Use FeatureClassToGeodatabase to copy feature classes
# to shapefiles
# Import system modules
import arcpy
# Set environment settings
env.workspace = "C:/data"
# Set local variables
inFeatures = ["climate.shp", "majorrds.shp"]
outLocation = "C:/output"
# Execute FeatureClassToGeodatabase
arcpy.FeatureClassToShapefile_conversion(inFeatures, outLocation)
