Master Geodatabase & User Schema geodatabase
3398
03-17-2014 11:13 PM
appsapps
We have a master geodatabase and 2 user-schema geodatabase (Projects & Survey namely);
From ArcCatalog - direct connect to "project" user-shcema GDB and choose SDE schema from the list.
Question:
Can I create feature class on SDE schema from user-schema connection?
1) If �?? YES then
Who will be the owner of the feature class? and
Where the table is get registered? In Master or User Schema GDB
2) If �?? NO then
We encounter situation here -
Action: -
Try to create new feature class �??  got an error message as below
�??Failed to create feature class.
User-schema owner cannot create/load data in master (SDE) instance�?�
Action �??
Click Ok on the above error message and
Try creating again now able to create without any error message?
Seems something wrong ? isn't?
Thanks in advance for your suggession
VinceAngelo
Esri Esteemed Contributor
No, you cannot create tables in the SDE schema as a user-schema user.
A user-schema geodatabase is a contract that you'll:
1) Only create tables as that user in that schema
2) Never create tables in any other schema
If you think you've found a bug, please contact Tech Support.
- V
EmadAl-Mousa
Action: -
Action �??
try granting the user-schema geodatabase the oracle role "DBA" privilege, then check.
please update us after performing the grant.
VinceAngelo
DBA access is never necessary for normal ArcGIS operation.  It is a dangerous security
practice to grant DBA unnecessarily, and there is no justification from this situation.
- V
appsapps
We got answer from ESRI for this issue!
This is a bug logged under NIM087273, The fix is available in 10.2.1 version.
Thanks for all suggestions
