Map package loads layers all attribute fields missing
3014
07-29-2014 03:14 PM
GabeKiritz
I'm working on a project using census data.  In the last week or so, all my recent map packages have stopped working.  Specifically, when I open them, they load everything up to date, including the group layers and layers that I've named and renamed, but nothing shows up on the map.  When I try to "open attribute table" on any of the layers, all of the records are gone.  The map loads fine if I open it from a Map Document - I'm just concerned about the point at which I need to share this with someone not on my computer.  Some screenshots below.  Thanks for any feedback you can provide!  ArcMap 10.2
GabeKiritz
I have also tried sharing as a Map Package using Enterprise Geodatabase Data and without doing so (referencing the data).  This started a week ago, and the map package from then has one layer's attributes still present, while the rest are gone.  The last few are missing all attributes.
