Making a "joined" field permanant in my database
784
12-26-2013 05:56 AM
MikeHenson
I have a database (shapefile) that has a joined table to it.  I need a field that is in my joined table to be a permanant field in my shape file so I can remove the join, but still have the field.  I thought I could just calculate a field, but when I do that it is still showing up as a joined field.  Can someone tell me how i can do this? Thanks.
MKH
TimWitt
If you are in an MXD, after you perform the join, right-click your layer and click Data -> Export Data...
The new shapefile should have the join in it and permanent.
Or you could use this tool, to make it permanent.
JoshuaDamron
Note: I believe that if you export your data any metadata you have created is not carried over in the export and will have to be recreated for the new feature class.
NidhinKarthikeyan
Regular Contributor II
The join should be made permanent for calculating the field.
Metadata will be carried over in the export.
JoshuaDamron
Thank you for the correction Nidhin, I didn't check my facts and was mistaken about metadata being carried over.
