KML to Layer tool arcgis 10.1
712
10-04-2012 06:32 AM
ChrisKisters
I have exported a shapefile to a kml-file in order to edit and share it with serveral persons in google-maps.
Finally I wanted to convert it again to a sharefile, using the new function of Arcgis 10.1.
To my regret I noticed that all the popup text is in one field (initially there were several fields to add text.)
Is there a way to avoid this?
Chris
BruceHarold
Esri Frequent Contributor
Hello Chris
If you want to preserve your attribute schema within a KML file, use the Data Interoperability extension to export to KML (the Quick Export tool will do it).  The core tool Layer to KML will output a single description field with HTML, which cannot be imported back into ArcGIS with any schema.
Regards
