Jake, does this mean that if we are using direct connects that your method of deleting old/orphan SID/SPID's at the SQL level is okay? We stop and restart our services every night and from what I can see of the processes, we have a bunch of orphans from yesterday out there in addition to the ones that started this morning. Will running this command clear those out? Thanks.
Brent,
It looks like you are connecting to you SDE geodatabase using an ArcSDE service. Have you considered using a direct connection? This is usually the recommended way to connect an SDE geodatabase.
