I have about 2,000 photos hylerlinked that is on a local drive. How can I change the drive of all photos without having to go to each to make the change.
3824
02-19-2015 07:24 AM
WalterBeard
OwenEarley
If you are storing your hyperlinks in a field then you can just update the path using the Field Calculator.
  • Back up your data or use an edit session so you can undo any changes.
  • For example - if your hyperlinks stored in a field called LinkPath:
  • Open the attribute table for your data
  • Open the Field Calculator for the hyperlink field
  • Change the Parser option to Python
  • Use the python replace function in your expression to change the path:
!LinkPath!.replace('C:\\Temp\\Photos', 'H:\\Photos')
This will replace C:\Temp\Photos with H:\Photo - just change the values to match your own paths.
TimothyKippo
Hi Walter
I would assume python would be the best method.  How are the hyperlinks stored?
OwenEarley
