I have 252 fields as a .CSV file. I would like to create a shapefile but I get the following error...
What is the work around for this?
While 250+ fields is an ugly database design, the error message is actually based on the 4000 byte record width limitation of dBase, which can be reached in as few as sixteen 254-character string fields. The dBase III specification also has a 100 field limit, which ArcGIS ignores, but it does honor the hard limit of 255 fields (field count is a single byte in the dBase header).
File geodatabase does not have the 4K buffer limitation, and supports 64K columns (which is far greater than the database limitations of 256 or 512, depending on ArcGIS version).
So your options are to slice the the table width to something that dBase can support or to use a format other than shapefile.
- V
There is also a limit of 10 for field name widths. You have several fields that are 11 wide. Also we don't support field names that start with a number, which you have several of.
CORRECTION: I reviewed our support for leading numbers in field names and I'm incorrect. We have no problem with leading numbers in shapefile field names and handle it when copy/pasting or exporting into another datasource that does not support leading numbers in field names.
Just asking for a clarification on the original question: Was the error box you show was encountered in Excel?
In ArcGIS
What of the suggestions listed in the above have you tried?
If you need to retain a shapefile output, then you have to overcome the limitations.
Have you tried the geodatabase option?
Hi Dan,
I personally prefer feature class in file geodatabase instead of shapefile for this. It works but the clients want shapefile as they don't understand GIS very well and gets lost when I tell them the similarities and differences between feature class and shapefile. I think I will shrink the number of fields to 140-150 field and see if that could help to create a shapefile.
I would gently guide them by setting things up by perhaps delivering a package of some form, so that they can open a project and it miraculously opens with the table ready for viewing and the dataframe fully set up.
It would be worthwhile to point out to them that having even 150 fields is going to be difficult to view, organize and comprehend.
A push in the right direction would certainly make your task less onerous and it will head off those...
"on second thought can you... " type requests which will inevitably follow.
Good luck
Don't forget about the 4000 byte record limit. You could store all the fields if the mean field width is less than 16.
Other products may enforce the 100 field limit of dBase, in which case the "140-150" field count would still fail (just later in the conversion process).
- V
OK, I was confused by your title of "I have 250 .... in excel" as meaning you were working in Excel. Are you just using the term excel in a generic sense to mean any table not associated with a current spatial data layer?
I initially created intersection points in ArcMap, added X-Y coordinates to those points and exported the table to .csv. Now I am manually entering data in the excel table. Once I am done I intend to import the table in GIS and create a shapefile using the X-Y coordinates.
I included a sample of 5 rows of my table. The final table will have anywhere between 470 and 500 rows.
