How to preserve circular arcs when exporting to DGW?
481
02-12-2017 12:16 PM
When exporting shapes to DWG, ArcMap converts my arcs to straight line segments. Is there a way to stop this?
Reply
sounds like there is more than a simple export...what properties are in your file?
Reply
I've already read that up and down, added fields, tried using a DWG as seed, nada. I only had limited success so far with the data interop extension which produces slightly less unsighty curves by creating more vertices.
Reply
