I have parcel maps, where each polygon represents for parcel.These polygons are made by "Feature to polygon" of polylines made from arc scan auto vectorization of a tiff files. These tiffs contains parcel IDs in the form of several set of consecutive numbers.Now i want to populate a field in the attribute table of the polygon feature named "Parcel ID" based on the my selection serial in editing session. In a nutshell what i want is to select polygon based on their "Parcel Ids", scribed on tiffs,serial (e.g.555,556,557,558) and the apply a field calculator script to populate with consecutive numbers(555-558) by python script,but problem is when i select polygons based on the Parcel ID serial they are not select in the attribute table accordingly rather in ascending order of FIDs/OIDs. I am to work on many of such tiffs, what can i do.
Thanks in advance...
