How to delineate/draw the edge of polygon automatically?
4094
12
02-07-2017 01:10 PM
Zihan_Lin
I would like to delineate the edge of my extraction below, not by hand, just automatically. I want to eliminate the inside polygons and keep the outermost edge only (highlighted by blue, not accurately). Could anyone give me some hints on this part? Thank you in advance!
Edge extraction
Tags (1)
DarrenWiens2
Run Dissolve without checking any of the dissolve fields.
If you just want the outline of a few polygons, select them, then run Dissolve.
Dissolve—Data Management toolbox | ArcGIS Desktop
Zihan_Lin
Thanks for the reply. Actually, the above image is what I got from running Dissolve.
DarrenWiens2
Are those lines or polygons?
Zihan_Lin
It's a large polygon with holes inside. Sorry for lack of information.
BlakeTerhune
You'll probably need to manually fill the holes inside or else it's always going to consider those part of the feature when you run Dissolve.
If you wanted to do it semi-manually, you can start editing and trace the boundary you want.
Creating segments by tracing—Help | ArcGIS Desktop
Also, you posted in the area for help using the GeoNet site. Tagging https://community.esri.com/community/gis/managing-data?sr=search&searchId=c25d959d-9dd7-4320-a287-94...‌ for better visibility.
Zihan_Lin
I finally manually edited the shapefile and also ran Eliminate Polygon Part tool. Thank you for the tagging suggestion.
DarrenWiens2
Ah, you can try Union-ing your existing file with another feature class containing a polygon that covers your entire area, then selecting and deleting the resulting "outside" polygon, and dissolving the "inside" polygons.
Zihan_Lin
That's smart! I'll try. I just manually edited the shapefile and ran Eliminate Polygon Part tool. It worked. But your suggestion is so creative.
AbdullahAnter
Honored Contributor
If you have Advanced license.Use Eliminate Polygon Part tool.
Eliminate Polygon Part—Help | ArcGIS Desktop
and input maximum hole area value in Area ( optional)
