How to clip 3 counties and its features to make a map from that?
949
06-04-2014 07:44 AM
MatthewPainter1
Can someone guide me through the process of cutting only 3 counties from my state out along with its features so i can make a map for this area?
MarkBoucher
You could copy the county polygons to a separate "mask" shapefile. You may or may not have to merge the polygons to make a "mask". Using this mask shapefile you can clip each of the different shapefiles to make new shapefiles for those that are just in the three counties. The tool for this is Analysis Tools.tbx\Extract\Clip. For rasters data you can use Spatial Analyst Tools.tbx\Extraction\Extract by Mask.
If you want to use the symbology from the original shapefiles, you can right click on each of the original shapefiles in Arc Map and choose "Save as Layer File". This creates a layer file which stores the property settings (symbology, labeling, etc.). To make this apply to your clipped shape files, bring the layer files in to your mxd (it will have the source of the original layer) and change the source for each one to be the clipped shapefiles.
There may be a tool that someone has made that will do all of this in one tool, but I don't know of one.
Another option would be to use a function in the Data Frame properties (right click the data frame and find at bottom of menu). Under the Data Frame tab, at the bottom, there are clipping options. This allows you to use a shapefile to clip the data without actually having to do all the stuff I mention above. There are problems with getting this to print on paper the way it looks on screen so before you do to much work, make sure it prints out as you want it with the clipped data frame.
One last option is to copy the state polygon and make the mask of the three counties as mentioned in paragraph 1 above. Then use the Analysis Tools.tbx\Overlay\Union tool on these shapefiles. Then delete the features in the shape file defined by the "mask". What you have is a reverse mask that you can lay over the rest of the data to mask it out. Edit the mask to expand it's outer edge as needed. This will do some of what the data frame mask does. You may have to deal with labels of features outside of the county boundaries though. Depends on how much labeling you plan on.
MatthewPainter1
um i never done this before and your answer was to complex 🙂
I want to keep everything the same just only need 3 counties on my map.
JoeBorgione
Or:
In an ArcMap session add your counties polygon feature class, right click on it in the TOC and choose properties: then select the Definition Query Tab.
In the Query Builder enter in CountyNameField = A or CountyNameField = B or CountyNameField = C and apply.(Where CountyFieldName is the field that has the county name in it and A,B,and C are the names you want.)
When only the three are visible, right click again your counties feature class in the TOC and zoom to layer.  This adjusts your extent.
Now right click any where in your dataframe and Select DataFrame Properties. Choose the DataFrame Tab.
Towards the bottom you'll see Clip Options; the default is No Clipping. Select Clip to Shape.
Click the Specify Shape... button.  Click Outline of Features. Under Features, select Visible.
Click Okay, and close; click Apply and close.
Add your data, build your map...
MatthewPainter1
much appreciated, and learned a lot. THANKS
