How do I delete an enterprise geodatabase from an instance in SQL Server?
4478
06-16-2015 12:08 PM
DavidWheelock
I have an ArcGIS 10.3.1 enterprise geodatabase in a new MS SQL Server instance that I just migrated from 9.3.1.  There are several live geodatabases in this instance.  I created a new, empty "test" geodatabase to try out the new "Create Enterprise Geodatabase" tool in ArcToolbox.  So, that worked, and now the new test geodatabase is taking up about half a GB of space and I would like to delete it.  However, ArcToolbox does NOT contain a "Delete Enterprise Geodatabase" tool or anything else that might be helpful in deleting the geodatabase in question.
I looked in the ArcGIS online help and can find nothing there about how to delete an enterprise geodatabase, either.
George_Thompson
Esri Frequent Contributor
Hi David,
You would just delete the database in SQL Server Management Studio.
There is no "out of the box" tool to delete enterprise geodatabases.
-George
GeodatabaseEnterprise GIS
--- George T.
George_Thompson
Hi David,
-George
--- George T.
QuinnFrancis
Hi David,
You'll need to delete the database on the RDBMS side (SQL Server).  DROP DATABASE should do the trick.
DROP DATABASE databaseName;
DROP DATABASE (Transact-SQL)
DavidWheelock
Thanks!  I thought that might be it.
Still, it would be helpful if ESRI would put a tool for that in ArcToolbox.
