This is probably a simple question, but is there a tool or file I can edit to change the boundaries of a TIF file in ArcMap 10.1?
Currently, I have an unprojected TIF file that I need to set into WGS_1984 and has boundaries of something stupid like
Top: 0.0000004
Left: -0.0000004
etc. etc.
I need to set those to
180
-90
etc.
for it to display correctly with other files that we have.
I know about changing the *.tfw extension, and then telling ArcMap to use the World file in the options. That won't work for me, as I don't want to have to do that one everyone else's machine. I also don't want to re-export them all, so if there's some kind of script I could write to change something in the XML file, that would be great.
Unfortunately, though I found those numbers in the *.TIF.xml document and changed all iterations of them, it made no difference even after closing and re-opening ArcGIS and ArcCatalog. They still displayed with the same limits in ArcGIS.
Thank you for any help!
