Has anybody been working with Canvec data recently? (Canada data)
507
5
11-07-2016 02:36 PM
Noah_McLaughlin
Hello fellow mappers.
I'm trying to join some downloaded CANVEC data (canada vector data sheets) to the  associated style file that is given along with the vector data.... But as where the data has been butchered (fields removed and ultered), I am unable to join on the respected code field.
Has anyone dealt with the data recently, and ran into this same issue?
Does anyone have a relatively quick work around?
Reply
DanPatterson_Retired
are you on this page ?? Prepackaged data sets | Natural Resources Canada
do note the codes have changed between the new and the old
 and then there is required read ... http://ftp.geogratis.gc.ca/pub/nrcan_rncan/vector/canvec/doc/CanVec_en_Specifications.pdf
and the root page
Free Data - GeoGratis | Natural Resources Canada
Noah_McLaughlin
Reply
should be the same data, unless there is difference between the prepackaged and the interactive (prepackaged link is just to the right of the search button which takes you to my links)
Noah_McLaughlin
I am aware the codes have changed, which made the data unable to be linked  as before, to the style file (ill attach it). My question is... is there a quick way to link the feature classes to the style file without updating the codes 1 by 1?
Reply
Don't do much stuff with styles, so that would make you the expert... but I am sure you are aware of this
Managing style contents—Help | ArcGIS for Desktop and if the CanVec data did a huge change, then one would presume that either the translation would be painless, or they forgot to include something with their data.  It might be worth linking to them as well.
Reply
