Getting rid of Green grid lines in Raster Mosaics
1262
08-15-2011 01:15 PM
KieranFitzsimmons
I have created the raster mosaic with some aerial photography  for my local authority , Im  very happy with the results , the only problem i have are the grid lines and extents window are still visible at the full extent , when i zoom into a particular area the green gridlines are still there .Is there anyway of not showing the gridlines , so in essence just the aerial photography, excuse my lack of knowledge as usually there is a slight tweak that will give me the results that i want , Any help would be appreciated
RobertBerger
Greetings,
I'm not quite sure I understand what you mean. Did you create a mosaic dataset or a raster dataset which mosaicked your air photos.
If you are talking about a mosaic dataset, then the green lines are footprints which you can turn off in the table of contents.
If you mosaicked several raster datasets into a single raster dataset, then you can play with the mosaic operators.
Again, I'm not sure if this is what you're looking for. I hope it helps.
Robert
