I get the error below when attempting to export my personal geodb to an xml file using GDB Designer 2. I have msxml 4.0 installed and running arcgis 9.3.1. I can import an exported workspace xml using direct export from arccatalog, however, the option to export from gdb designer 2 fails.
Please help.
Thanks.
Flavor: Access
Version: 2.3.0
DATABASE: C:\Test_pgd.mdb
An application error has occurred. The error desciption follows:
DATE: 9/22/2011 11:04:25 AM
DLLVERSION: 2.0.381
DLLDATE: 12/20/2006 5:06:40 PM
PROCEDURE: ICommand_OnClick ExportGDB.cls (74)
ERRORDESCRIPTION: StartGeodatabaseOperation modImportExport.bas (5078)
NewXMLDocument modCommon.bas (224)
ERRORNUMBER: -2147024770
ERRORDESCRIPTION: Automation error
The specified module could not be found.
