Geocoding
3851
9
11-12-2014 03:08 PM
trevonjohnson
Can anyone post the link where I can get x,y coordinates from? I need these coordinates to geo locate addresses.
MirceaMaierean
To batch geocode I suggest using the free* TAMU geoservices. They give you about 5000 free credits to use.
FeliciaSenn
TAMU has a truly phenomenal geocoding service.
trevonjohnson
I am getting the same coordinates for each address im putting in..that can not be right.
FeliciaSenn
Are you using their online batch geocoder? Or their desktop application? I've never used their desktop application, so I can't speak to the validity of it. However, when I needed 300 some addresses geocoded, their online batch coder was perfect. Here's the link for the batch geocoder: Free online database geocoding services from Texas A&M Geoservices
If you have ArcGIS for Home edition (and the credits) you can also use the Esri geocoding engine.
Otherwise, if you're really strapped for credits and aren't comfortable uploading to TAMU, QGIS (Welcome to the QGIS project! ) is a free GIS platform which can support a Python plug-in that will geocode for you through the internet (installation instructions for plugin: MMQGIS ). This solution isn't as accurate as Esri's offered geocoding, but if you're just making a map for fun, practicing, et cetera, it will make shapfiles for you that can be imported into Esri's available layers. I used this when I was experimenting with GIS and learning how shapefiles worked.
trevonjohnson
I have my X,Y coordinates in an excel sheet with other information as well. i have a blank shape file created.. How do i add the excel sheet into the attribute table?
MirceaMaierean
File > Add Data > X,Y Data... inside Arcmap and choose excel sheet with the X,Y add them to the option fields and choose the coordinate system they were collected in typically the geographic WGS84 or NAD83.
trevonjohnson
I am having trouble putting this excel spread into my attribute table.
MirceaMaierean
what do you mean by trouble? do they plot but show NULL values? Do they plot in the wrong location? They don't plot at all?
JoeBorgione
Personally, I think excel is a wonderful spreadsheet application, but it's just that; a spreadsheet. My suggestion is to import it into the flavor of geodatabase you prefer and follow this link.
