GDB to KML using kml_style_id
1265
05-13-2011 08:29 AM
deleted-user-h2MwrUDd3vgt
I'm trying to develop an ETL tool to translate all of the feature classes in a file geodatabase to a single KML file. I have everything worked out, but am having difficulty figuring out how to set up the kml_style_id so that it will split out each of the values in a field into a separate style in order to change the symbology accordingly. I would greatly appreciate any suggestions or guidance.
BruceHarold
Esri Frequent Contributor
Hi Nathan
Try AttributeFilter with the Import option to create separate output ports for each attribute value, set the ID value you want per port and connect all paths back together again.
Regards
That did it, thanks!
