GDAL Plugin Debugging
1293
02-21-2012 10:37 AM
SebastianWalter
Dear Forum,
I wrote a GDAL plugin for a special raster dataset I want to use. The gdal*.exe tools work fine on the data, and after registering the plugin in ArcMap, the data is shown in ArcCatalog. But when I want to add the dataset to the view in ArcMap, an error message says: "Invalid raster dataset. Failed to create raster layer."
I carefully followed the guide in this download: http://resources.arcgis.com/gallery/file/image-management/details?entryID=457D0F2B-1422-2418-7F4B-51...
Does anybody know a way to debug this?
Thanks a lot in advance for any help!
Regards, Sebastian
SebastianWalter
Although I did not find a solution to the GDAL plugin debugging, I got my GDAL driver working with my dataset. The CPL_DLL directive was missing before the GDALRegister_ method. This difference to the GDAL standalone driver is not mentioned in the ArcGIS plugin documentation (see above link), but is clearly visible in the provided example.
SebastianWalter
