FME workbench crashing
177
01-09-2012 12:31 PM
ChristineAndrews
For some sudden reason, everytime I try to edit spatial ETL tool through arccatalog, the FME workbench has started crashing.
(running 9.3.1 on o/s xp sp3)
I initially thought another extention may be interfering, so turned everything off except data interop, no cigar!
MitaHajirakar
Hi Christine,
Are you able to send me your toolbox so I can investigate whether something has gotten corrupt inside of it?  Also, are you able to create a new SpatialETL tool and open it for editing?
You also mentioned that this suddenly started happening.  Did you recall installing anything on your computer before this problem began?
Kind regards,
Mita Hajirakar
Safe Software, Inc.
ChristineAndrews
Hi Mita,
Thanks, I will do.
I am getting the same behaviour when creating a new tool, it opens then after a few seconds I get the error.
There has been nothing installed recently, and the tools are working fine when run, I just cannot edit ='(
MitaHajirakar
Hi Christine,
It sounds as if a re-install or repair is worth a try....have you tried this already?
Mita Hajirakar
Safe Software, Inc.
