Finding similar submissions based on location from Survey123 Data?
44
08-05-2020 08:13 PM
I'm currently working on a project where volunteers submit location-recorded photos through Survey123 of physical features in a certain area.
Part of the process involves filtering out submissions that other volunteers submitted previously, which involves comparing photos. I'm thinking the best course of action is to find submissions (represented in point features) and narrowing down my search to point features within 3 feet (or another distance) to each other within the same layer.
Any idea on a geoprocessing tool or script that would help me accomplish this? I've tried using the Select by Location tool but it just selects every record.
Thank you for reading!
Reply
MVP Frequent Contributor
Kevin, you could try
Generate Near Table (Analysis)—ArcGIS Pro | Documentation
using the featureclass as both inputs to the tools since.
If a Search Radius is specified and no near feature is found, no record will be output.
The same feature class or layer may be used as both input and near features. In this situation, the input feature being evaluated is excluded from the near features candidates to avoid all features being closest to themselves.
... sort of retired...
Oh this is perfect! Thank you so much.
Reply
