Field Calculator - Adding HTML and changing File Paths
1452
07-09-2014 02:43 PM
TaylorKerr
Howdy,
I am using ArcMap 10.2.
In my data, I have an "Image" field that contains a file path.
I am wanting to add HTML content to both ends of this field.
The end result, a frame that displays the Image when using the HTML Popup Tool.
The tricky part is that I need to replace part of the File Path in the process.
Instead of a mapped drive, I need to replace the first part of the File Path with the name of a server which the picture resides.
Example Original "Image" path: C:\Folder\Folder\Picture.jpg
Example Changed "Image" path: \\\\\Server\Folder\Folder\Picture.jpg
Example Changed "Image" path with Frame: <img alt="File" src="\\\\\C:\Folder\Folder\Picture.jpg" width="416" height="312"/>
Being new to ArcGIS, perhaps I am over my head with this undertaking.
Surely there is a way to do this in bulk to all of my Features.
Any ideas?
AnthonyGiles
You can find and replace in the attribute table by using control + f. This will allow you to change C:\folder to \\\\server. You can add to the end of your text by right clicking on the column header and select field calculator in the syntax add the fieldname & "text you want to add in speech marks"
AnthonyGiles
TaylorKerr
Thank you for your reply, Anthony!
Getting creative with your Find & Replace suggestion, I was actually able to get things to work!
Turns out, the major issue I was having was that the Field Calculator wasn't using quotation marks like I wanted it to.
Find & Replace worked like a charm.
I was able to change and mold over 300 Features in only a few steps.
Thanks again for the suggestion and advice!
