field calc is off by one character,, by calculating the right4 characters from source field into blank 4 char long field it comes up 1 number wrong - 3 times in 220
243
07-25-2017 01:24 PM
markdynge
New Contributor III
added cropped screen shot of what happens
two tables joined upon parcels
inactivenos and sourcenos
tsource  length 10 string
newno length 4
I have tried in python and vb
both come up with newno as being the next # higher
as though they were rounded up,
that in my humble opinion is like rounding "why" to "whz"
JoshuaBixby
MVP Esteemed Contributor
Given the rounding appears to be happening with only a few records, and not all of the records, it makes me think something is up with the data at some level.  If there was a rounding bug in general, you would see many more or all of the rows being impacted.
What are the data sources of the two tables being joined?  File geodatabases?  Shape files?  Something else?
If you run the following code in the interactive Python window, what does it return for the 2 fields in question:
lyr = # layer or tableview name
desc = arcpy.Describe(lyr)
for fld in desc.fields:
    print fld.name, fld.type, fld.length, fld.precision, fld.scale
markdynge
New Contributor III
Josh, both tables are in a file geodatabase, after some more digging and eye strain, the join i used had the potential to be one-to-many, even though the table viewed in the screen shot had the one number in it, a manual field calculate brought up the 'invisible' 2nd joined item, which just happened to be 'numerically' sequential.
Thanks for the reply
MitchHolley1
MVP Regular Contributor
Is the field you're calculating from a Double type?
markdynge
New Contributor III
Thanks Mitch for the inquiry, the fields were Text only, one field was 4 char in length the other was 10 char in length, It was a mistake (on my part) to presume what I saw was what I got, the join – based on parcels, was a 1 to many. The 3 miscalculations were just referencing a second point within the parcel which happened to be sequentially higher.
