Features turn invisible after Add Join
1501
03-04-2016 11:32 AM
MarcelAfif
New Contributor III
I want to join a feature class A with polygon features to another feature class B with point features based on a common field. I'm using add join. After it completes, the polygons are invisible. That is, I cannot see the polygons in ArcMap although when I select them in the attributes table, they are selected on the map (only the edges appear in blue).
What is the reason behind this behavior?
Reply
DanPatterson_Retired
MVP Esteemed Contributor
were both layers added to arcmap to begin with?  were they both visible before the join? they are in the same coordinate system I hope?  any further details?
Reply
MarcelAfif
New Contributor III
Hi Dan.
Both layers were added in arcmap, both had the same coordinate system, and both were visible before applying the join and after removing the join.
I found a way to do what I want, which might be helpful to my fellow ArcMappers:
(1) In TOC, right click on the layer you want to "filter"
(2) Scroll down to "Joins and Relates > Relate..." and navigate through the dialog
(3) Now open the attributes table of the second layer
(4) Click "Table Options > Select All > Related Tables"
