Failure to “post” changes from child versions to parent,
3118
18
09-04-2015 07:33 AM
JamalNUMAN
Honored Contributor
In the screenshots below, three child versions are taken from the parent version (default).
Same feature is edited in the three child versions.
Changes in the child versions are detected and “Reconcile” is applied
“Post” has introduced the message below
Then how the changes in the child versions can be posted to the parent?
Does the ArcGIS detect the conflicts between the child versions?
Does the ArcGIS resolve the conflicts between the child versions and then resolve them with the parent?
Thank you
Best
Jamal
Reply
JamalNUMAN
Honored Contributor
This new thing for me; that updating same feature in different child versions is considered as conflict (particularly id multiple editors are updating same feature in same version).
Before, I thought that conflict IS LIMITED TO updating the same feature in both parent and child version.
Reply
AsrujitSengupta
Regular Contributor III
We always learn something new everyday
Reply
AsrujitSengupta
All the 4 connections are with 'sa'?
JamalNUMAN
Honored Contributor
At all! Connections are made with different users (ali, amjad and sami) as shown in the screenshots below
Reply
AsrujitSengupta
Exactly...so when you perform the reconcile, use the Connection which was connected with 'sa'...change to the other version and then do the reconcile.
JamalNUMAN
Honored Contributor
well. If the “start editing” is started selecting the default version as the target, then neither “reconcile” nor “post” are activated! Then how changes in the child versions can be transferred to the default?
Reply
AsrujitSengupta
Follow the below workflow:
1. From the connection as 'sa' user> add the feature class into ArcMap
2. Change Version to the child version
3. Now start editing
4. Now do the Reconcile
You should get the conflict
JamalNUMAN
Honored Contributor
Thanks Asrujit.
I’m not sure why this is the only scenario that works; I mean to firstly add the default version (with sa credentials) and then to switch it to a child version and next to apply the reconcile\post (in editing environment).
Reply
AsrujitSengupta
It will work even when you connect with any 'sysadmin' login and connect to the child version to perform the Reconcile\Post.
