Export Feature Attribute to ASCII (point) not correct
4300
12-18-2014 04:55 PM
martywalters
New Contributor III
on the map the point is at  117°14'55.187"W  32°42'8.256"N
when i export to ASCII the point is -13052047.60890000 3855854.73170000
I'm using
Projected Coordinate System:WGS_1984_Web_Mercator_Auxiliary_Sphere
Projection:Mercator_Auxiliary_Sphere
XanderBakker
Esri Esteemed Contributor
The export is using is using the projected coordinate system. The latitude longitude are probably configured for display of the coordinates in the data frame.
martywalters
New Contributor III
when I create feature class for ArcMobile using
"Geographic Coordinate Systems" of WGS 1984  I can't "Export Feature Attibutute to ASCII"
error "000916 : The input feature class does not appear to contain projected data"
I need to create a feature class that can be added to ArcMobile project center with a offline map.
ArcMobile  needs the feature class and the OFFLINE -> Basemap Layer to be the same spatial reference.
