Error while posting child version to default "Out of server memory"
1311
04-11-2012 08:55 PM
VaibhavKapur
Hi All,
While positng a child version to default we are getting the following error:
"The version could not be posted.Out of server memory"
We are using arcsde version 9.3.1 with sp1 and sp2 installed for oracle11g on a linux machine.
If anybody know solution to this problem kindly help out.
Regards,
Vaibhav Kapur
anthonysanchez
New Contributor III
Hi Vaibhav,
Are you using direct connect or application connections (2 or 3 tier)?  If you are using 3 tier check your sde logs.  Also - Check with your your sys admin/dba for that linux box and see if any errors were thrown in the system logs or in the alert log for the database.
Anthony
