HiIm trying to upgrade my 10.0 SDE (on oracle 11g) to 10.0 SP5. For doing that i am using ArcCatalog 10.0 SP5. Running the gp tool Upgrade Geodatabase results in error:
Executing: UpgradeGDB "Database Connections\NRGISD as SDE.sde" PREREQUISITE_CHECK UPGRADE
Start Time: Wed May 29 12:31:55 2013
Paused the database for upgrade.
There are no other active connections.
User has privileges required to upgrade.
Connected RDBMS instance is setup for ST_GEOMETRY configuration.
Running Pre-Requisite check (C:\Users\Administrator\AppData\Roaming\ESRI\Desktop10.0\ArcCatalog\NRGISD as SDE.sde).
Instance supports XML type.
Updating ArcSDE server tables and stored procedures.
Could not update ArcSDE server tables and stored procedures.
Unpaused the database.
Failed to execute (UpgradeGDB).
Failed at Wed May 29 12:32:05 2013 (Elapsed Time: 10.00 seconds)
At the bottom of sde_setup.log file i see the following:[Wed May 29 12:35:49 2013] Unable to load Type st_domain_stats_body, underlying DBMS error encountered.
[Wed May 29 12:35:49 2013] ERROR setting up st_geometry type.
Error: -51
[Wed May 29 12:35:49 2013] DBMS error code: 24344
ORA-24344: success with compilation error
[Wed May 29 12:35:49 2013] ERROR setting up St_Geometry, Error = -1
But in the content of sde_setup.log i can see that object 'Body st_domain_stats' is created. Any hints on this?Log files from setup are attached.
