Can anyone out here help me to get the proper files to fix this ? I had no clue how it got it to PDF ?
See the red circle I drew it. It is a .dbf file and it is a database that was saved when I create a shapefile...
Could you screenshot your dbf files to share ?
That is the dBase portion of the shapefile... *.shp, *.shx and *.dbf are normal plus other file extensions.
That is expected. Do you want it to be a *.pdf file?
No. just want to change back to default file... Not sure which to set a default file .
Ahhh, so somehow your file association with *.dbf got set to *.pdf.... Follow George's advice.
I'd like to thank you everyone here.... I was able to get my pdf reset to back to where it was like before I accident hit the pdf to set as a file asscioate with the dBase file....
Well I was able to get that fix and I just went into this site:
I was able to open it in ArcCatalog and make sure it can read it. Yes it reads it just like exactly what you see it .
Here is the screenshot.. I havehighlighted as yellow color to show it to you...
