Data Interoperability Connection OK Greyed Out
688
05-15-2012 03:07 PM
AnthonyTrilsbach
I am trying to convert some mapinfo files in the .tab type format. When I open the data interoperability connection, I can load the .tab file and the 'pink' bar correctly identifies this as a MapInfo file. I am happy that everything is OK but the OK button is greyed out, so I can't actually do anything. Can anyone help?
TT
MitaHajirakar
Hi TT,
You are in the "Interoperability Connection" dialogue box, correct?  Did you select the format as well as a .tab file for the dataset?  Once these are both filled in the OK button should be enabled.
Kind regards,
Mita Hajirakar
Safe Software, Inc.
mettegreve
Just had the same thing happen. You don't specify a name for the dataset under 'Dataset' - only the folder where it should be placed. Then the 'OK' button is available and the .tab-file get's the same name as the input dataset.
