I am building a custom address locator style for Malaysia in 10.6, using the US Address style as the base for customisation.
Here are some info to provide context to my problem.
I am using HERE NavStreets as the reference data. NavStreets data support both point address and dual ranges addresses.
The typical Malaysian house address consists of the following components:
No. 2 Jalan Eaton 5 Kuala Lumpur City Centre 50450 Kuala Lumpur
where
Prefix to denote a house number | House | Street Prefix | Street Name | Locality | Postcode | District |
No. | 2 | Jalan | Eaton 5 | Kuala Lumpur City Centre | 50450 | Kuala Lumpur |
The format of my customer addresses to be geocoded contains the following fields:
ADDRESS | POSTCODE | ZONE
where ZONE is an internal zoning system used by the company for aggregating customers. Example of a ZONE is 25003.
ADDRESS is a single field address with all components separated by space.
I have two questions:
1. So far I have succeeded in customising the address style to batch geocode using the ADDRESS and POSTCODE fields. However, I have failed to create the locator with the custom ZONE field. Where did I go wrong with the mapping schema? See attachment for the locator style I have created.
2. For apartments and POIs, where should I customise in the locator style to score on building names? Example of an apartment address below:
Block A10-3-21 Eaton Heights Jalan Eaton 5 Kuala Lumpur City Centre 50450 Kuala Lumpur
where
Unit | Building Name | Street Prefix | Street Name | Locality | Postcode | District |
Block A10-3-21 | Eaton Heights | Jalan | Eaton 5 | Kuala Lumpur City Centre | 50450 | Kuala Lumpur |
Thanks All!
Jon
