Creating Oracle User Schema Geodatabase
5511
11-18-2011 08:38 PM
EmadAl-Mousa
I am trying to create a user schema Geodatabase in ArcSDE 10 Geodatabase. I have followed the steps in the attached PDF file, i have granted the oracle user the required privileges:
GRANT ADMINISTER DATABASE TRIGGER TO SSDGEO;
GRANT CREATE LIBRARY TO SSDGEO;
GRANT UNLIMITED TABLESPACE TO SSDGEO;
GRANT CREATE INDEXTYPE TO SSDGEO;
GRANT CREATE PROCEDURE TO SSDGEO;
GRANT CREATE TRIGGER TO SSDGEO;
GRANT CREATE OPERATOR TO SSDGEO;
GRANT CREATE SEQUENCE TO SSDGEO;
GRANT CREATE VIEW TO SSDGEO;
GRANT CREATE PUBLIC SYNONYM TO SSDGEO;
GRANT CREATE TABLE TO SSDGEO;
GRANT CREATE SESSION TO SSDGEO;
GRANT CREATE TYPE TO SSDGEO;
GRANT DROP PUBLIC SYNONYM TO SSDGEO;
In Addition to the following:
grant execute on DBMS_LOCK to public;
grant execute on DBMS_PIPE to public;
However when i execute the sdesetup command:
sdesetup -o install -d ORACLE11G -i 5151:SSDGEO -u SSDGEO -l /apps/arcsde/sde_10_auth/authorization.ecp
I receive the following Error:
ESRI ArcSDE Server Setup Utility Sat Nov 19 06:35:26 2011
ERROR: The geodatabase already exists. If you want to upgrade the geodatabase,
see the ArcSDE installation guide for instructions.
ERROR: Geodatabase install not completed.
i have attached snapshots of my command output, and sdestup.log errors.
When i view the user schema, i find the "system tables" has been created successfully !!
However, under SDE schema "INSTANCE" system table, i don't see that the child geodatbase has been added.
Regards,
Emad
by Anonymous User
Not applicable
Original User: mousaem
The Solution i had is the following:
The oracle user schema geodatabase should have the following privileges:
GRANT DBA TO XXXX
GRANT CREATE TYPE TO XXXX;
GRANT CREATE ANY TRIGGER TO XXXX;
GRANT EXECUTE ANY PROCEDURE TO XXXX;
GRANT GRANT ANY ROLE TO XXXX;
GRANT CREATE ANY SEQUENCE TO XXXX;
GRANT CREATE ANY VIEW TO XXXX;
GRANT DROP ANY TABLE TO XXXX;
GRANT DROP ANY PROCEDURE TO XXXX;
GRANT CREATE OPERATOR TO XXXX;
GRANT CREATE ANY PROCEDURE TO XXXX;
GRANT CREATE VIEW TO XXXX;
GRANT ANALYZE ANY TO XXXX;
GRANT CREATE PUBLIC SYNONYM TO XXXX;
GRANT CREATE LIBRARY TO XXXX;
GRANT CREATE PROCEDURE TO XXXX;
GRANT CREATE ANY INDEX TO XXXX;
GRANT GRANT ANY OBJECT PRIVILEGE TO XXXX;
GRANT GRANT ANY PRIVILEGE TO XXXX;
GRANT DROP ANY SEQUENCE TO XXXX;
GRANT CREATE SEQUENCE TO XXXX;
GRANT DROP ANY VIEW TO XXXX;
GRANT DROP PUBLIC SYNONYM TO XXXX;
GRANT ALTER ANY INDEX TO XXXX;
GRANT CREATE ANY TABLE TO XXXX;
GRANT CREATE TABLE TO XXXX;
GRANT ADMINISTER DATABASE TRIGGER TO XXXX;
GRANT CREATE TRIGGER TO XXXX;
GRANT SELECT ANY SEQUENCE TO XXXX;
GRANT DROP ANY INDEX TO XXXX;
GRANT SELECT ANY TABLE TO XXXX;
GRANT ALTER ANY TABLE TO XXXX;
GRANT CREATE SESSION TO XXXX;
GRANT CREATE INDEXTYPE TO XXXX;
GRANT EXECUTE ON SYS.DBMS_LOCK TO SSDGDB;
GRANT EXECUTE ON SYS.DBMS_PIPE TO SSDGDB;
where XXXX is the user schema geodatabase.
Then Execute the following SDE Command:
sdesetup â??o install â??d ORACLE11G â??u XXXX â??i 5151:XXXX
XXXX: is your user schema geodatabase
Notes:
If for some reason the geodatabase was not successfully created. You can deleted it using:
sdesetup -o delete -d ORACLE11G -u XXXX -i 5151:XXXX
You Need to check under your SDE Schema that the system table "INSTANCE" has a new entry with your new user schema geodatabase "XXXX".
Also you need to check under the newly created user schema geodatbase "XXXX" that in the system table "VERSIONS" has an entry:
NAME - OWNER - VERSION_ID - STATUS - STATE_ID - DESCRIPTION
DEFAULT XXXX 1 1 0 Instance default version.
The new schema's created under the user schema geodatabase should be created using "SDE" user. you can grant the schema the following privileges:
GRANT RESOURCE TO "schema"
ALTER USER "schema"DEFAULT ROLE ALL;
GRANT CREATE TABLE TO "schema";
GRANT CREATE SESSION TO "schema";
I have attached a snapshot image of how to connect to your new schema under your user schema geodatabase.
you can create multiple schemas under your user schema geodatbase, and those will be isolated from the master SDE schema geodatabase. if you look under "TABLE_REGISTRY" in your user schema geodatbase you will find only the tables and objects you have created under the schema user geodatabase.
Regards,
Emad Al-Mousa
EmadAl-Mousa
I have missed a step:
before executing the sdesetup command to create the geodatabase, you need to export your DBTUNE file and change the parameter DATA_DICTIONARY.
sdedbtune -o export -f DBTUNE_XXX -i 5151 -u sde
after exporting replace the DATA_DICTIONARY section with the following:
##DATA_DICTIONARY
UI_TEXT ""
XML_IDX_INDEX_STRING "PCTFREE 0 INITRANS 4 NOLOGGING"
XML_IDX_INDEX_PK "PCTFREE 0 INITRANS 4 NOLOGGING"
XML_IDX_INDEX_ID "PCTFREE 0 INITRANS 4 NOLOGGING"
XML_IDX_INDEX_DOUBLE "PCTFREE 0 INITRANS 4 NOLOGGING"
XML_DOC_VAL_LOB_STORAGE "NOCACHE NOLOGGING CHUNK 4K PCTVERSION 5 DISABLE STORAGE IN ROW"
XML_DOC_UNCOMPRESSED_TYPE "BLOB"
XML_DOC_TEXT_TYPE "LONGRAW"
XML_DOC_STORAGE "PCTFREE 0 INITRANS 4"
XML_DOC_MODE "COMPRESSED"
XML_DOC_LOB_STORAGE "NOCACHE NOLOGGING CHUNK 4K PCTVERSION 5 DISABLE STORAGE IN ROW"
XML_DOC_INDEX "PCTFREE 0 INITRANS 4 NOLOGGING"
XML_COLUMN_STORAGE "SDE_XML"
S_STORAGE "PCTFREE 10 PCTUSED 90 INITRANS 4 STORAGE (FREELISTS 4 MINEXTENTS 1 PCTINCREASE 0)"
S_INDEX_SP_FID "PCTFREE 10 INITRANS 4 STORAGE (FREELISTS 4 MINEXTENTS 1 PCTINCREASE 0) NOLOGGING"
S_INDEX_ALL "PCTFREE 10 INITRANS 4 STORAGE (FREELISTS 4 MINEXTENTS 1 PCTINCREASE 0) NOLOGGING"
RASTER_STORAGE "BLOB"
RAS_STORAGE "PCTFREE 10 PCTUSED 90 INITRANS 4 STORAGE ( MINEXTENTS 1 MAXEXTENTS UNLIMITED PCTINCREASE 0 FREELISTS 4)"
RAS_INDEX_ID "PCTFREE 10 INITRANS 4 STORAGE ( MINEXTENTS 1 MAXEXTENTS UNLIMITED PCTINCREASE 0 FREELISTS 4) NOLOGGING"
GEOMETRY_STORAGE "SDEBINARY"
F_STORAGE "PCTFREE 10 PCTUSED 90 INITRANS 4 STORAGE (FREELISTS 4 MINEXTENTS 1 PCTINCREASE 0)"
F_INDEX_LEN "PCTFREE 10 INITRANS 4 STORAGE (FREELISTS 4 MINEXTENTS 1 PCTINCREASE 0) NOLOGGING"
F_INDEX_FID "PCTFREE 10 INITRANS 4 STORAGE (FREELISTS 4 MINEXTENTS 1 PCTINCREASE 0) NOLOGGING"
F_INDEX_AREA "PCTFREE 10 INITRANS 4 STORAGE (FREELISTS 4 MINEXTENTS 1 PCTINCREASE 0) NOLOGGING"
D_STORAGE "PCTFREE 10 PCTUSED 90 INITRANS 4 STORAGE (FREELISTS 4 MINEXTENTS 1 PCTINCREASE 0)"
D_INDEX_STATE_ROWID "PCTFREE 10 INITRANS 4 STORAGE (FREELISTS 4 MINEXTENTS 1 PCTINCREASE 0) NOLOGGING"
D_INDEX_DELETED_AT "PCTFREE 10 INITRANS 4 STORAGE (FREELISTS 4 MINEXTENTS 1 PCTINCREASE 0) NOLOGGING"
BND_STORAGE "PCTFREE 10 PCTUSED 90 INITRANS 4 STORAGE ( MINEXTENTS 1 MAXEXTENTS UNLIMITED PCTINCREASE 0 FREELISTS 4)"
BND_INDEX_ID "PCTFREE 10 INITRANS 4 STORAGE ( MINEXTENTS 1 MAXEXTENTS UNLIMITED PCTINCREASE 0 FREELISTS 4) NOLOGGING"
BND_INDEX_COMPOSITE "PCTFREE 10 INITRANS 4 STORAGE ( MINEXTENTS 1 MAXEXTENTS UNLIMITED PCTINCREASE 0 FREELISTS 4) NOLOGGING"
BLK_STORAGE "PCTFREE 10 PCTUSED 90 INITRANS 4 STORAGE ( MINEXTENTS 1 MAXEXTENTS UNLIMITED PCTINCREASE 0 FREELISTS 4)"
BLK_INDEX_COMPOSITE "PCTFREE 10 INITRANS 4 STORAGE ( MINEXTENTS 1 MAXEXTENTS UNLIMITED PCTINCREASE 0 FREELISTS 4) NOLOGGING"
B_INDEX_XML "PCTFREE 0 INITRANS 4 NOLOGGING"
B_INDEX_TO_DATE "PCTFREE 0 INITRANS 4 NOLOGGING"
B_INDEX_SHAPE "PCTFREE 10 INITRANS 4 STORAGE (FREELISTS 4 MINEXTENTS 1 PCTINCREASE 0) NOLOGGING"
B_INDEX_RASTER "PCTFREE 0 INITRANS 4 NOLOGGING"
AUX_STORAGE "PCTFREE 10 PCTUSED 90 INITRANS 4 STORAGE ( MINEXTENTS 1 MAXEXTENTS UNLIMITED PCTINCREASE 0 FREELISTS 4)"
AUX_INDEX_COMPOSITE "PCTFREE 10 INITRANS 4 STORAGE ( MINEXTENTS 1 MAXEXTENTS UNLIMITED PCTINCREASE 0 FREELISTS 4) NOLOGGING"
A_STORAGE "PCTFREE 10 PCTUSED 90 INITRANS 4 STORAGE (FREELISTS 4 MINEXTENTS 1 PCTINCREASE 0)"
A_INDEX_XML "PCTFREE 0 INITRANS 4 NOLOGGING"
A_INDEX_USER "PCTFREE 10 INITRANS 4 STORAGE (FREELISTS 4 MINEXTENTS 1 PCTINCREASE 0) NOLOGGING"
A_INDEX_STATEID "PCTFREE 10 INITRANS 4 STORAGE (FREELISTS 4 MINEXTENTS 1 PCTINCREASE 0) NOLOGGING"
A_INDEX_SHAPE "PCTFREE 10 INITRANS 4 STORAGE (FREELISTS 4 MINEXTENTS 1 PCTINCREASE 0) NOLOGGING"
A_INDEX_ROWID "PCTFREE 10 INITRANS 4 STORAGE (FREELISTS 4 MINEXTENTS 1 PCTINCREASE 0) NOLOGGING"
A_INDEX_RASTER "PCTFREE 0 INITRANS 4 NOLOGGING"
ATTRIBUTE_BINARY "BLOB"
MVTABLES_MODIFIED_INDEX "INITRANS 4 TABLESPACE SDE STORAGE (INITIAL 2M) NOLOGGING "
VERSIONS_INDEX "INITRANS 4 TABLESPACE SDE STORAGE (INITIAL 128K) NOLOGGING "
VERSIONS_TABLE "INITRANS 4 TABLESPACE SDE STORAGE (INITIAL 256K) "
STATES_TABLE "INITRANS 4 TABLESPACE SDE STORAGE (INITIAL 1M) "
STATE_LINEAGES_INDEX "PCTFREE 0 INITRANS 4 TABLESPACE SDE STORAGE (INITIAL 5M) NOLOGGING "
B_INDEX_USER "PCTFREE 0 INITRANS 4 TABLESPACE SDE STORAGE (INITIAL 40K) NOLOGGING "
B_STORAGE "PCTFREE 0 INITRANS 4 TABLESPACE SDE STORAGE (INITIAL 40K) "
XMLDB_INDEX_TAG "YES"
XMLDB_INDEX_FULLTEXT "NO"
XML_IDX_TEXT_UPDATE_METHOD "NONE"
XML_IDX_TEXT_UPDATE_MEMORY ""
XML_IDX_TEXT_TAG_STORAGE ""
XML_IDX_STORAGE "PCTFREE 0 INITRANS 4"
XML_IDX_INDEX_TEXT ""
XML_IDX_INDEX_TAG "PCTFREE 0 INITRANS 4 NOLOGGING"
XML_INDEX_TAGS_INDEX "INITRANS 5 TABLESPACE SDE STORAGE (INITIAL 1M) "
XML_INDEX_TAGS_TABLE "INITRANS 4 TABLESPACE SDE STORAGE (INITIAL 1M) "
MVTABLES_MODIFIED_TABLE "INITRANS 4 TABLESPACE SDE STORAGE (INITIAL 2M) "
STATES_INDEX "INITRANS 5 TABLESPACE SDE STORAGE (INITIAL 128K) NOLOGGING "
STATE_LINEAGES_TABLE "PCTFREE 0 INITRANS 4 TABLESPACE SDE STORAGE (INITIAL 7M) "
B_INDEX_ROWID "PCTFREE 0 INITRANS 4 TABLESPACE SDE STORAGE (INITIAL 40K) NOLOGGING "
END
Then Import the DBTUNE file again:
sdedbtune -o import -f DBTUNE_XXX -i 5151 -u sde
after that you can proceed with executing the sdesetup command to create the user schema geodatabse:
Where XXXX: is the schema geodatabase name
REMARK:
To delete schema user geodatabase, you can use the following command; make sure all users should be disconnected from SDE:
sdemon -o kill â??t all â??i 5151 â??u sde
