Creating new Attribute Table with Attributes form other feature classes
790
04-29-2013 01:09 AM
AlexanderPichlmayr
Hello everybody,
My team and I are working on a projekt to connect data created in ArcGis to an other Software. Therefore we have to modify the attribute table of a polyline feature that we create during the projekt (we draw a energy distribution grid). The problem is that the required attribute table format contanins the vertic points coordinates of the polyline feature. While drawing the lines the vertics are not added to the attribute table. The basic idea that we got so far is to create a second point feature that contains the X and Y coordinates of the vertics. So now we have one feature with the polylines and an other with the vertic points. Now we are searching a way to add the information from the point feature attribute table to the linefeature attriburt table. We already tried with spatial adjustment but it seams that this tool can not copy from a column into a row. For better understanding I attached a picture that explains the path that the attributes should be transported from one table to the other. Once the "ObjektID" and the "ORIG FID" are equal the data in the column relates to one row. An other idea that we are wondering about is if there is a possibility to add the vertic coordinates directly wile drawing (that would simplify a lot) .Still we dont have any idea if what we want to do is even possible in ArcGIS so we are very greatful for any kind of support. (We work with ArcInfo 10)
Thank you very much for any comment or help
Alex
MelanieSummers
Occasional Contributor III
Hi Alexander,
I would suggest using a spatial join.
Best,
Melanie S.
DanaNolan
To do this while digitizing, you can use the Editor's Show Vertices window. It may not be real graceful to copy these values into a table, but you can see X and Y as you draw the polygons.
AlexanderPichlmayr
Hi Melanie. How would you prosceed with Spatial Join? I mean when I create a Spatial Join between the line feature and the point feature with the vertics I will get a new output feature class but how would you add the vertic coordinates to the attribute table then?
@ dknolan: yes thanks that would be a way to add the coordinates manually but as the grid that we draw is very large it would kill us to add each coordiante one by one.
