Creating a "pick list" (drop down menu) for a geodatabase
7046
11
02-15-2013 12:41 PM
JohnM
Just joined the forum, hoping someone can help me out. I'm attempting to create a pick list in ArcMap/Catalog and can't seem to get it down. I've created a geodatabase with coded domains (that I thought would generate a pick list but didn't), created a feature class within the geodatabase, exported to a shapefile, and placed that file into my mobile device (Juno hand held). The coded domains I create show up alright, but not with any pick list associated like I need. Any help/advice/links would be much appreciated.
Thanks!
BlakeTerhune
You can move it into another geodatabase and ArcGIS should also copy the associated domains with it. Like you discovered, Shapefiles do not support field domains; it needs to be in a geodatabase (File or Personal). And, as Leo D. mentioned, a feature class can only exist in a geodatabase.
If you need to deliver the data to someone in a format other than a geodatabase, you have two obvious options:
  1. Include the domain values as a table that can be joined.
  2. Field calc the exported data to replace the domain code with the domain description for easier interpretation.
LeoDonahue
You can't move just a featureclass, it exists within a geodatabase.  you have to move the geodatabase.
