Create Replica failed. Line string or poly boundary is self-intersecting
831
01-24-2013 09:15 PM
FMGLGIS
Hi there,
Has anyone come across this error when trying to create a replica in ArcSDE
"Create Replica Failed.  Linestring or poly boundary is self-intersecting"
[ATTACH=CONFIG]21047[/ATTACH]
I thought it was related to "inconsistent spatial extents" but after fixing this it didn't solve the error message
Regards
Alex
MarcoBoeringa
MVP Regular Contributor
How was this data loaded in your ArcSDE geodatabase? ArcSDE normally runs a thorough check during loading of data using ArcGIS tools, preventing self-intersecting geometries in your database, but if this was an already existing spatial database without ArcSDE geodatabase repository that you "enabled" as a geodatabase, there may be invalid geometries / shapes in the database.
Anyway, running the Check Geometry and Repair Geometry tools is likely to fix these issues.
