could not load data from the data source. unable to create logfile system tables.
675
06-16-2014 07:18 AM
LubnaGeorge
[ATTACH=CONFIG]34612[/ATTACH]hi all,
i am facing the attached error message while editing data in ArcMAP 10.1
message error looks like this: could not load data from the data source. unable to create logfile system tables.
my geodatabase is hosted in Oracle 11gR2.
can someone help please
EmadAl-Mousa
Occasional Contributor III
for stand alone log file for ArcSDE (check this: http://resources.arcgis.com/en/help/main/10.2/index.html#//002n0000001400000000
under "Permissions required for stand-alone log files", permissions required are:
  • CREATE SESSION
  • CREATE TABLE
  • CREATE TRIGGER
  • CREATE SEQUENCE
  • CREATE PROCEDURE
or you can grant "resource" oracle role to the user.
Regards,
EmadAl-Mousa
  • CREATE SESSION
  • CREATE TABLE
  • CREATE TRIGGER
  • CREATE SEQUENCE
  • CREATE PROCEDURE
Regards,
LubnaGeorge
Thanks, it worked.
